Most Famous: Caliburn Pod System Kit
The
Caliburn Pod Kit by Uwell is a brand-new pod system by the company famous mostly for their larger vape devices, i.e. tanks and box mods. The Cailburn is designed to be ultra-portable and is shaped more or less like a Juul or similar cig-a-likes, albeit with a great deal more power and versatility. As a compact pod system device, the Caliburn features a two-piece setup with a 520mAh battery and separate, disposable pods with integrated coils. As always, let’s check out the specs on this device before throwing it over to the reviewers for their thoughts.
1.Specs
Dimensions: 110 x 21.2 x 11.6 mm
Construction: Aluminum Alloy
Battery: 520mAh
Capacity: 2.0mL
Wattage Output: 11W
Pod Coils: 1.4ohm
2.Features
Dual Firing Options – Draw- or Button-Activation
Pro-FOCS Flavor Technology
Dual 3.5mm Fill Ports
Voltage-Based Output
You may also like:
Caliburn A2Caliburn G2Caliburn G
