Visa obesvarade inlägg | Visa aktiva trådar Aktuellt datum och tid: 2022 07 04, 11:54
Svara på tråd  [ 1 inlägg ]
 Top sale vape such as aspire flexus q...
Lärjunge
Bilmodell: no one
Inlägg Top sale vape such as aspire flexus q...
New year, new atmosphere, all things update. Your electronic cigarette is also updated. In order to welcome the new year, our website has new products and great discounts. If you are just looking for the electronic cigarette that suits you, then you can follow me to take a look! Celebrating the Chinese New Year holiday! 10% off sitewide. DATE: 2022.1.19- 2022.2.7. Let's take a look at a few of them, such as aspire flexus q, oxva origin mini, smok pozz pro.
1. Details of aspire flexus q
Aspire Flexus Q Kit is powered by built-in 700mAh battery to prolong vaping performance greatly. With Q-Quick Type-C 3A super fast charging, it can reach up 80% charge in 10 minutes. The 3 level adjustable power modes can better satisfy your vaping needs. The dual activation modes, auto draw&button triggered, make it easy and convenient to use. The AST Chipset makes Flexus Q Kit safe to use. Flexus Q Kit is compatible with Flexus Q Pod and AF 0.6Ω&1.0Ω Mesh Coil. Flexus Q Pod has 2ml e-juice capacity and side&bottom filling system. In addition, the AF 0.6Ω&1.0Ω vertical Mesh Coil can produce evenly heating and denser flavor.
2. Details of oxva origin mini
The OXVA Origin Mini is created for on the go with a built-in battery of 2200mAh and wattage up to 60W. It's now smaller, stylish and equipped with the proven Unicoils.The design of OXVA Origin Mini Kit 4ml is Stylish & Pocket-Friendly.OXVA Origin Mini is powered by unicoils.Unicoils not only have the best flavor of its kind, more importantly they don't leak while most coils from major brands have leaking issues.8s Longest Vaping Time offer a better vaping experience for you.New photon chip has six safety protection modes,Which are Short-circuit Protection, Over-time Protection ,Output Over-current Protection, Over-temperature protection, Over-charge Protection, Over-discharge Protection.
3. Details of smok pozz pro
Smok Pozz Pro Kit is a pod system kit designed with textured metallics and tested durability. SMOK Pozz Pro Pod Kit works with built-in 1100mAh battery with max 25W output and 90min type-C charging. In addition, you can adjust 4 levels of airflow with the slider to get the flavor you like. Pozz Pro Pod Kit can be activated by button or air. SMOK Pozz Pro Kit is packed with a 2.6ml pod that is compatible with LP1 coils featuring 3 silicone rings for leakproof experience.
After reading these products, is there nothing you want? Do you want to know more? There are also many e-cigarettes on this site vapormo.com, you can click the link to come in and take a look, there is always one you like.
2022 01 22, 5:02
Forum style by ST Software.
